jmill
Aug 28 2011, 08:51 PM
Where can I get a decent price and not wait 3 weeks for them?
EdwardBlume
Aug 28 2011, 09:03 PM
Try your luck with a want ad. Or you could call GPR...
Eric_Shea
Aug 28 2011, 10:10 PM
Are you racing this car?
markb
Aug 28 2011, 10:13 PM
Have you called us to see what we have on the shelf?
pcar916
Aug 29 2011, 03:03 AM
Rich Bontempi at High Performance House (Redwood City, CA) may have some as well.
J P Stein
Aug 29 2011, 06:03 AM
22mm front T-bars are mighty stiff for a 914...unless you're going racing.
jmill
Aug 29 2011, 09:12 AM
QUOTE(Eric_Shea @ Aug 28 2011, 11:10 PM)
Yup. It'll see some street time but I'm building a road race car with minimal to no street comforts.
I have 225# rear springs and will be in the market for a 23mm bar when funds allow.
QUOTE(markb @ Aug 28 2011, 11:13 PM)
Nope. I will today.
J P Stein
Aug 29 2011, 09:56 AM
For a data point:
My 21mm T-bars were balanced by 275 lb rear springs, 22mm (effective) AR bar set half hard. No concessions to streetability.
jmill
Aug 29 2011, 04:28 PM
QUOTE(J P Stein @ Aug 29 2011, 10:56 AM)
For a data point:
AX or Road Course?
pcar916
Aug 29 2011, 04:49 PM
Mine's a track car in the same ilk.
Front
23mm torsion bars
22mm Tarrett bar
Bilstein sport inserts in Bilstein struts
Rear
200# springs
yellow adj Koni's
no AR bar
Elephant poly-bronze in the back and about to be in the front when I get a day free to install them.
Now that I built the last tranaxle with a clutch-type LSD I'll have to add a rear AR bar or "up" the rear springs to fight a wee bit of understeer.
I don't care if it's a bit stiff... so am I. I use it almost daily as well and damn the tire wear. We have a lot of real twisties in Arkansas.
J P Stein
Aug 29 2011, 05:59 PM
QUOTE(jmill @ Aug 29 2011, 03:28 PM)
For a data point:
AX or Road Course?
AX. My front end weighed in at about 700 lbs, about 1000 in back.
I've driven a 914 track race car on an AX course. He could get away with stiff suspenders on a billard smooth track but was undriveable at speed out in the parking lot.
IIRC his rear springs were in the 600 lb range on a 1900 lb car.
Jeffs9146
Aug 29 2011, 07:30 PM
I have a set of torsion bars that I got from an 82 sc but I couldn't find any markings to indicate what they are!
If you know how to tell what they are I will take a closer look for you!
$40 plus shipping.
jmill
Aug 29 2011, 08:51 PM
They'll most likely be 18.8mm. Just measure the outside diameter (not at the splines). I have a set of them I got with the 911 front end.
I emailed GPR. None on the shelf. They'll let me know tomorrow if their supplier has them.
Jeffs9146
Aug 29 2011, 11:25 PM
I will check them tomorrow and let you know the outside mesurment!
Jeffs9146
Aug 30 2011, 04:23 PM
Sorry, mine are 19mm!
vtursi60
Aug 30 2011, 05:31 PM
I have set of 23 mm torsion bars 911 .
jcd914
Aug 30 2011, 06:51 PM
I know some here warn about too stiff but not all of us.
Set mine up 20 yrs ago and I loved it.
911 T frt struts & brakes
Polygraphite suspension bushings fr & rr (hard ones)
22mm front T-bars (914)
180 lb rear springs (cut and shortened)
19mm front anti roll bar (heim jointed drop links)
Koni yellow sport gas shocks frt & rr.
Daily driver, auto-x and occasional road trip.
Very balanced car.
Was always near the top of my auto-x class (not saying much since it was a 1.7L)
Jim
Jeff Hail
Aug 30 2011, 06:54 PM
Sway Away solid 22mm bars PN# SAW1822 for 74-89 911 Turbo.
Never used, brand new. $225 includes shipping.
Click to view attachmentPM me if interested.
Jeff
jmill
Aug 30 2011, 07:06 PM
PM sent. Turbo has the same arm and spline count?
