So, what other considerations are there?
The fact that a 17mm t-bar is "basically" unavailable for the 911 spline count. It's called a rare 914-6 t-bar. I don't know of anyone making one.
And the effective spring rate of a torsion bar goes up with the FOURTH POWER of the diameter, so doubling the diameter of the bar gives you SIXTEEN TIMES the spring rate.
That depends on bar length and lever (t-bar center to ball joint) length but, sounds accurate.
Who here has that 23mm master cylinder / aluminum crossmember combination and can report?
URO makes a 23mm MC that is the same dimensionally as the 17/19mm unit. Not sure if I trust them yet but... they're out there.
You mention 19mm bars but later say keep stock bars. I thought stock 914 bars were something along the lines of 17mm?
I think we're referring to the fact that you mentioned:
most people upgrade the thickness of the bar regardless of 914 or 911 orgin
I was just referrencing that the 911 uses a 19mm stock (18.8 actually, these are in inches I believe with that being 3/4") and the 914 uses a 17mm stock. I like stock spring rates for "both" cars respectively and an adjustable sway bar for street applications. Again, that said, my car is sitting on the 19's right now as Jeff recommends. We'll see...
The advantage of the 914 arms is, you get to run the stock spring rate. You can also get some other spring rates but, I believe the 911 spring rates are more prevailent.
Advantage of the 911 stuff is, as above, the 911 spring rates are probably more vast and available.
