Murphy hit me this weekend – crap.
I rebuilt the carbs on the -6 this weekend. On Saturday night, after finishing the first one, I sat back could not believe how much I enjoyed doing it. Now, granted, I did not have to mess with any throttle shaft issues – just a good cleaning, new gaskets, seals, needle valves, jets, acc pump and a float adjustment.
On Sunday, I jumped back in and started on carb number 2. Everything was going great until I went to remove the needle valve access bolt on the top of the casting. The SOB would not budge. After a few hours of PB blaster and then some heat, it finally broke free. Unfortunately it took a very small piece of the casting with it (the piece was probably a 32nd deep and no more than 1/16th long right on the top flat sealing surface). Being that this is located right next to the gas inlet for the carb, I spent a good two hours with a fine file and various grits of emory paper smoothing out the area. But, I am still concerned about having a leak.
Any thoughts? (capn, you out there?)
I have extra aluminum washers that go under the access bolt. I thought about adding an additional one for a bit of extra “squish” at the seal.
… or do I need a new carb top? (dreading this…)
Looking into the fuel inlets, I do not see any difference in the distance in the depth that the access bolt goes into the casting. Needle valves went in easily – nothing affected there at all. I am just concerned about a potential leak.
It was a real let down after everything going so well.
Thanks for any thoughts/ideas
-Scott S
