I need one of the bolts/spacer/washer set for the seat belt secure point on the b-pilar/roll bar.
Someone have a car your parting that you can pull one off?
Kev
kconway
Aug 29 2011, 08:35 PM
Actually, I could use a set of retractors complete as mine are a bit frayed. Don't suppose they are available new anymore?
Kev
Aug 29 2011, 08:38 PM
QUOTE(kconway @ Aug 29 2011, 10:35 PM)
Kev
I've heard that the ones from 944's work. Maybe do a search or wait for someone to comment.
bdstone914
Aug 29 2011, 10:24 PM
Kevin,
I have a few set of good belts.
I used to remove passenger seat belts from VW Rabbits which are longer and cut back the worn end with the buckle to the 914 length. I then took them to an upholstery shop and had the ends resewn. No they are not DOT approved but he used more thread and it was stronger.
You can also buy new the same strenght web material and have them made.
I can see what I have in the way of nice belts.
I should have the mounting hardware with them.
You need to come out to Riverside and see the shop.
I must have some other parts you need.
Bruce
