Running carbs on a 4cy is there any need to keep the relay board or could it be replaced, with something cleaner and more modern.
What I know the relay board does.
1. Voltage Regulator for alternator (could I make a custom mount for the voltage regulator?)
2.Rear Window Blower (not used)
3. Heater blower realy (not used)
4. Fuel pump relay (not used in my application of switched and fused pump)
5. Fuses for blowers and pump (not used)
Comments?
Have you done it?
What does it require?
Any adapters for the regulator?
