QUOTE(andys @ Sep 3 2011, 01:59 PM)
QUOTE(76-914 @ Sep 3 2011, 12:06 PM)
Do it at the fuse panel. There is no reason not to on this car. It's super easy. Disconnect - at bat, remove the 2 screws holding the fuse block up and you'll find what your looking for. There might exist a double spade on 10 or 11. I can't remember which one it is but both of my 914's had this extra available spade. No matter; you can slip 1 or 2 doublers on at the fuse block. You won't have to cut or splice any factory wiring this way. And again, it's super easy.
I need both a switched and a constant 12+, so I need to know the function of 10 or 11. As I mentioned earlier, I can't check anything with the DVM with no power at the moment.
Thanks,
Andys
From 74 wiring diagram:
Fuse 8 Power with key on, no power while cranking (X circuit - accessories)
Fuse 9 Power key on and cranking (T15 circuit - ignition)
Fuses 10, 11, 12 Battery power (hot all the time)
Jim
