Hi guys
I am back with unsolved problems..
I have 73 with 1.8 european engine (VIN starts with AT and according to Dave, AT is from a European-spec VW 412. http://tunacan.net/t4/reference/case.htm)
So I thought the car has FI but now I do not know what it has..ha...ha.. yes I simply do not know anything...
Anyways let me start with the most visible issue the car has.
Well I mentioned on the other post that I had a tune up from this place.
They worked on replacing 4 spark plugs, wire set, and oil change, wire to injector foul EDI adjust timing & A/F meter and he was mentioning of valve so perhaps valve job done as well?
After tune up the car runs better as they set the idle higher but still has problem turning on if it sits for couple hours or less...
Once the car starts, it starts pouring out gas and air(massive amount of white gas).
Someone from Pelican had asimilar issue and people were mentioning of doing valve adjustment. (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/334985-914-1-7-4-carbs-spitting-gas-exhaust-carb.html). As of this point, I am not sure if this is caused by the valve job that was done by my mechanic or something else.(I did not have this issue before I had the tune up so I guess it's their fault?) What would be the solution?
When the car is initially started, idle is set on 1200-1300 no oil pressure light on, then the car starts vibrating (that's when gas and air starts coming out of the exhaust) and idle starts going down.. if it hits below 1,200, oil pressure light starts blinking. Eventually car dies.. Basically car does not hold the idle when warm. (Car died when I reduced the speed to exit freeway too) Any suggestion?
Thank you guys I will post more pics later so those will give you better idea where I should start from
