QUOTE(RiqueMar @ Sep 7 2011, 01:17 PM)
QUOTE(mepstein @ Sep 7 2011, 10:08 AM)
Capt my capt - what do you think about a stock 6 hard line for the return on a 3.2 vs a larger converted 911 line like what PMS sells.
sorry for the hijack enrique
No, no! It's no hijack at all! I was thinking the same thing when I saw the PMS oil line, but my concern, again, is with the Heat Exchangers.
I know eventually, I will put in a front mounted oil cooler, however for the time being I'll be sticking with stock.
I agree, I want a solution that works with heat exchangers.
I think it's perfectly fine for you to try stock and upgrade if needed. You have your shop and you do the work. Since Scott is doing my car, I'm trying not to have too many do-overs. We've already had a couple earlier in the build - my fault, my money.
