Bullet
Jul 14 2004, 07:57 PM
Im trying to troubleshoot why my Horns do not work. Im using the haynes manual, looking throught the wiring digrams and i see thet there is a Horn relay. but when i look under the relay location section it does not say where it is located. could someone please tell mw where this is located. It is on a 75 2.0L
ChrisReale
Jul 14 2004, 09:39 PM
Unscrew the fuse panel, and drop it down, it is on top of the fuse panel. Second from the right if I recall correctly
Dave_Darling
Jul 15 2004, 03:31 PM
The exact position can vary depending on how many beers Klaus had for lunch before installing the relay sockets. Check the colors on the wires going to the relay against the wiring diagram. (Color on Pelican or in the PDF manuals, B&W in Haynes.)
--DD
