Ok, I thought I was chasing vacuum leak. I checked with propane (yes this works) and found none.
Simptom is when hot I can screw throttle body adjustment screw all the way in to have idle at ~ 800-900. needless to say it won't idle before its' hot set like this.
So if you set idle for the 2-10 min warmup time at ~ 900, it idles at ~ 1500 to 1700 when hot.
Checked air box. Ohm readings are good, flapper moves fine. looks very good.
aux air regulator is also good.
What do I check next? Don't I have to have vacuum leak if it idles hot with adjusting screw in all the way?
