Mark Henry
Jul 16 2004, 05:56 PM
There'd be big nickies captain!
Guess I'll be building a 103 X 78mm monster T4 this winter
So far...
103mm Nickies on the way
ceramic lifters on the way
30mm pump have
2.0 heads have
1.7 rockers and p-adj's have
case, bearings and stuff have
78mm crank need
rods need
cam need
SS valves and stuff need
SDS fuel injection have
I need to start making up my christmas wish list
URY914
Jul 16 2004, 06:19 PM
What are you going to do for rods?
Scat? Carillo? or...?
Paul
Mark Henry
Jul 16 2004, 09:45 PM
CB performance rods...I've already talked to Jake (at the June Jitter Bug show in Canada) and most likely I'll get my crank, rods and cam from him.
Seeing Jakes 105mm Nickies sold me on getting my set. A 94mm T1 cylinder fit inside it, all but the top couple of fins.
Jake Raby
Jul 16 2004, 10:00 PM
SWEET! Just call me up when you get ready to rock!
URY914
Jul 17 2004, 06:34 AM
CB Super Race Rods?
Why those?
Paul
Jake Raby
Jul 17 2004, 10:39 AM
CB makes all my rods for my engines up to 2316cc... They are close to the rods that they sell, but I use better bolts than they come with.. The CB rods are strong, have correct big end and small end weights and thay also have the smallest caps for better clearancing.
I am also a dealer for Carrillo, and all the "Super Heros" get those as a standard.
The CB rod is good for 220HP and 8,000 RPM out of the box. I have had them fail, but I have also had Carrillo's fail as well... Its usually not a rod related problem that makes a rod fail.
Hell, I have ran stock Type I rods inside TIV engines with 200HP and they worked just fine! The key is a lightweight piston, and wrist pin as well as a correct rod ratio and piston speed. This all can easily be calculated to ensure the rod that you choose will hold the revs you need.
URY914
Jul 17 2004, 03:59 PM
So you take the Super Race Rods and install different bolts. Do you use ARP bolts?
Paul
