i bought a panasonic cd/mp3 player and it came with a wiring harness. all the speaker cables are hooked up with no problems. but the head unit is not getting any electricity. there was a Blaupunt amp and a no name head unit installed in there before, so i ripped them out
i only have three wires left to connect to the head unit. they are labled as such on the harness that came with the cd player.
1. Continuous 12V
2. ACC (i assume this is from the ignition)
3. Ground
The ground is no problem there are two brown wires left over from the removal of old HU and amp. i will remove one of these and use the other one for the ground.
i used a voltagemeter (multimeter?) and measured the three wire bundle that went into the old head unit, and whether the ignition is on or not, there are no 12v electricity. do i just keep going back wards and check where the elec. stops on these wires that suppose to have power? i replaced two inline fuses but still no juice. i checked the fuse panel under the dash (visually and with continuity check), and all the fuses are good. what am i missing here.
oh, i didnt know that different color fuses mean different ampage or resistence, so i might have put at least two of the fuses back in the wrong place. can anyone tell me what color goes where?
ug, this is so frustrating, i installed the same cd player in my accord w/o any problems. but 914 elec problems is part of the joy of owning a 914, no? <_<
