bigkensteele
Sep 18 2011, 02:47 PM
I made a nifty little C shaped tool and pulled the fan hub with no problem. Managed not to lose the woodruff key. Now, I am scratching my head trying to figure out how to actually extract the old seal without damaging my case. Tried several searches without luck. Anyone?
PRS914-6
Sep 18 2011, 04:16 PM
You didn't say if the engine was in or out.....Try driving a sheet metal screw in it and then you can grab it or use it to pry on
bigkensteele
Sep 18 2011, 04:21 PM
Got it. I used a large screw driver, with a hard piece of plastic between the screwdriver and the case, and pried it out. Took a bit of force, but once it gave, it popped right out.
Engine is out of the car on a stand.
Thanks,
Ken
get off my lawn
Sep 20 2011, 11:20 AM
sawzall woulda worked too. :-)
914werke
Dec 9 2011, 09:47 AM
Did you have the shroud off ? is it possible to do by just removing the Impeller?
