• Type 4 case clearanced for stroker crank- “W” case w/ oil galley plug mod. Bore alignment checked by Rimco
• DPR 78.4 mm crank
• 5.4" H-Bean rods w/ ARP bolts balanced end to end
• Reciprocating assembly dynamically balanced by Jake Raby
• 96mm Keith Black pistons/AA cylinders/Hastings rings
• Static compression 9.854:1 and dynamic compression 7.380:1
• Manton chromoly push rods individually sized for each intake/exhaust
• Heads 44x36mm SS valves, matched ported/polished w/ dual valve springs and 911 swivel adjusters as well as chromoly studs for exhaust and rocker studs.
• ARP case bolts/nuts
• Full flow oiling w/ -8AN stainless steel braided lines w/ additional heat resistant cover.
• Split duration cam RAT (Raby) 9501 w/ double thrust cam bearings from Jake
• DTM cooling upright cooling system + tig welded and balanced fan (for higher rev capacity)
• Jenvey 42mm throttle bodies w/ 30#/hour Bosch "Red" top injectors
• K&N filters for each stack
• Jakes bell crank throttle linkage
• CB intake manifolds drilled for MAP signal
• -6 AN Aeroquip for fuel -8AN for oil
• RAT T1 killer FF Oil pump cover
• Megasquirt ecu
o v3.57 board w/ MS3 + MS3x + relay board
o Sequential ignition and injection but easily set to wasted spark if desired
o Ls2 coil near plugs
o Cam trigger wheel (modified Vanagan unit) and 36-1 trigger wheel (from Mark de Bernardi)
o all Weather Pack or OEM bosche terminals in engine bay, 2nd MAP sensor added for continuous barometric reading
o Wiring harness all high grade wiring from DIYautotune or marine grade stuff wrapped in Techflex and heat shrink
• LC-1 WBO2 sensor for AFR, TPS, IAC sensor, cht in head wired to ECU as well as MAP signal from a cnc aluminum manifold to smooth pulse
• Custom CNC motor mount for a 912 to bolt to stock location
• Custom Turbo Thomas 4 into 1 1-5/8" header w/ Magnaflow muffler (bungs for EGT on #3 and for AFR past collector)
• Flywheel 914/Sachs pressure plate/disk all balanced w/ above reciprocating assembly by Jake
• Bosche fuel pump
• Engine assembled with all quality German Kolbenschmidt/Mahle bearings and Victor Reinz seals/gaskets. I will include a NOS spare main Mahle main bearings std/.010” (no longer available and difficult to locate!)
The motor has been very well cared for w/ vigilant monitoring of temps (CHT, EGT and Oil pressure via Dakota Digital gauges) and frequent oil changes w/ Brad Penn or Swepco only. It is still in my car and will stay there until it’s sold so if you want to go for a spin, you wont be disappointed.
While I hate to part ways, but I need to make room for the new engine. Selling price is $9000 for engine and all parts listed above. Locals have first dibs, SF bay area, but I’m willing to ship at buyers expense. If payed by paypal, buyer assumes 3% charge. Open to offers. If you are interested it the motor without the fuel injection system, I am sure we can work something out.
Please do feel free to contact me.....ron at iwolfe dot com
Photos and videos:
Track Video:
Chasing down 68 911 with a 2.7L and a lot of fiberglass and lexan – Buttonwillow, CA
http://vimeo.com/23708527
Chasing down everything I can – Thunderhill, CA
http://vimeo.com/21850766
