Typically, is it more cost effective to send a package using the Post Office or UPS?
Also on the rear left hand brake I had a wheel bearing that I had replaced but when taking a left hand turn, it makes an intermittent sound as it turns.
What kind of brakes are on the back? We also had to tighten the rod where the swing arm is mounted.
It looks like there is a 81 stamped on the outside of the caliper and something that appears to be a P I think also?
It appears that the inside edge of the tire has a tad bit of wear, I presume from when the bearing was bad??
My mechanic here thinks the pad and rotor might be worn uneven and glazed a bit and should be replaced??
Mainly when taking a left hand corner it chirps a bit. Driving down the road it vaguely sounds like there is a minute noise.
Click to view attachment Click to view attachment
