QUOTE(matthepcat @ Sep 21 2011, 11:49 AM)
Heat? I have built in heat from the coolant hoses running under the floor pan, front trunk air sneaking into the cabin and no insulation!
No need for additional heat in LA, but this might be neat instead because of the AC. I know they are reselling another mfg, maybe antique auto air or equal might be cheaper. But you know Renegades will fit! Need compressor also.
$399 HEAT/AC UNDER-DASH UNIT: This three vent under dash unit can be used as a heater only or for heat and AC. It comes with a three-speed fan switch, powerful blower motor, blend control, three directional vents, AC evaporator and heater core, all enclosed in a trim-line under dash case.
$185 AC CONDENSER: To be mounted in front of Renegade cooling system.
$85 RECEIVER DRYER: Essential part of AC system.
