QUOTE(ezbngreen914 @ Sep 23 2011, 12:22 AM)
I have a stock 1.7 and I'm wandering if an ignition upgrade would be a good move. Sounds some what easy and cheap. Is this one of those no brainer improvements or are there pros and cons. What would you recommend? What product? Looking for some good old 914 world input.
Any other cheap and easy no brainer upgrade suggestions are also welcome (anything that will help the engine breath easier, etc).
looking to improve my 914 a couple of hundred bolt on $ at a time.
I have been running a Hot-Spark unit- very similar to the petronix- replaces points- i think its a manetic rather than optical, i probably have about 1,000 miles now with this and no problems, - it eliminates the need to set the points and dwell. just set the timing and valve lash,.
when i did mine i put in a new high energy coil, plugs and plugwires, as i was having unknow electrical/spark issues, so i just did it all, (ended up being a ground and F.I. wiring issue) but really happy i have all new stuff i should not have to touch for a very long time.
www.hotspark.com
