For 16" rims
http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yesKumho Ecsta XS
265/45R16
Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “W” = 168mph (270kph) 99W SLMax Load = 1,709 lbs
Max psi = 51 psi
Treadwear: 180
Traction: AA
Temperature: A180 AA A 1709 lbs.
51 psi
8/32"
28 lbs.
Rim range 8.5-10"
Measured rim width 9"
Section width 10.5"
Tread width 9.7"
Diameter 25.4"
or if you're racing, same size, but stickier
http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yesKumho Ecsta V710
265/45R16
Max psi = 51 psi
Rounded Shoulder Treadwear: 30
Traction: C
Temperature: A30 C A 1709 lbs.
51 psi
4/32"
24 lbs.
Rim range 8.5-10"
Measured rim width 10"
Section width 11.2"
Tread width NA
Diameter 25.2"
Both tires also have a 225/50R16 available that will fit 6"-8" rims for the front of the car
