QUOTE(Porsche Rescue @ Jul 19 2004, 07:16 AM)
Should the Shnorr washers be replaced every time the joints are disconnected (if not wired)?
Also, I recall someone telling me that the bolts on a 911 were "stretch bolts" and should also be replaced every time.
new washers every time.
the 8mm bolts are fairly highly stressed and they are not expensive, certainly not in relation to the potential damage. i like to replace them every time but i won't claim that it's actually worked out that way IRL. but - since you almost always need new CV gaskets, it's no more difficult to order up a shipset of bolts and washers at the same time.
the CV bolts on my '71' 911 are 10mm and much stouter. i don't think any of them are officially one-time-use stretch bolts but like i said - the 8mm ones are fairly highly stressed. witness the number that actually break when being torqued to spec - this tells you the tension load is pretty close to ultimate...
BTW - the booth next to Ross-Tech at Waterfest this weekend was
MetalNerd and they had some great show specials on quality tools -- i picked up a proper 8mm triple-square 3/8" drive socket, made by Wright (a good name) for $8. i also picked up a 10mm for the 911, and a 14mm impact-rated Allen for the Subie's cylinder head drain plugs. check these guys out, he specialises in VW Diesel applications but was extremely responsive to meeting specialty tool needs.
