BK911
Sep 24 2011, 12:54 PM
95k on original engine with FI.
All of a sudden I cant rev past 4k. Runs pretty good until then, but just nothing after. I mean NOTHING. If I am going up hill the car will cruise up at 3900 rpm but will not accelerate at all. Kinda sucks living in the mountains!
Did a leakdown and got 4 4 6 6, so not the best but not too bad.
Checked ignition timing with vac disconnected. Petronix ignition but stock coil.
This part kinda confuses me.
@ 2500 rpm red mark was 0 BTDC white was 20 BTDC
@ 3000 rpm 5 and 25
@ 3500 5 and 25
This shows the marks are 20 degrees apart. I thought they were supposed to be 27? I cant find a black mark.
Setting the timing using either mark does not make a big difference.
Any ideas?
TheCabinetmaker
Sep 24 2011, 01:16 PM
My first thought when i saw the title was " too much dwell", but you don't have points. Maybe replace with points and condenser to verify the pertronics is not the culprit.
poorsche914
Sep 24 2011, 01:28 PM
Is something restricting the fuel flow? Clogged filter or fuel pump not working properly?
jaxdream
Sep 25 2011, 09:06 AM
Sounds like your distributor advance plate is not advancing right. I personnaly would try the points , your Pertronix is working , just don't kill it by leaving the ignition on with out the engine running. You still using OEM FI , more than likely using the stock distributor. hook a vaccum pump ( Mighty Vac ) of some sort to the Vac.Advance check to see how much the advance plate moves , go from there to the already suggested clogged fuel filter , check to see what pressure the pump puts out , also check the injectors for output. Jeff Bowlsby's website has a good check list for D-Jet , maybe check his info out. Good Luck.....
Jack
