QUOTE(r_towle @ Sep 28 2011, 02:26 PM)
Thankfully we are not pushing aerodynamically challenged, overweight and underpowered buses around with our little motors.
I would suggest you track down the proper early Heat exchangers and muffler if you are going to remove the system....
The 75/76 heat exchangers retain to much heat under the motor bye directing it forward first....
backdating the HE system has more benefits than just the additonal HP you will obtain...it will make the motor run cooler.
Rich
Remember, I said "combustion chamber temps". While somewhat related to overall engine temps, there is a difference. '75 1.8s run REALLY lean, and that makes 'em have high combustion chamber temps, resulting in an increased possibility of dropping a valve seat or breaking off a valve. Obviously, it makes sense to do all you can to drop overall engine temps by doing the things you suggest, but it's not likely to cool the CCTs as much as you'd like, IMO.
The Cap'n
