QUOTE(bliggity @ Sep 29 2011, 09:54 PM)
I'm near Atlanta, sounds like if it's a mps or trigger points they are both tough to find ones in good working condition right?
Check thru the other stuff first, but if all else is o.k. trigger points plate can be had for about $200 new, . M.p.s. can be tested, check to see if it holds vacation. If not, place an add in classifieds. Usually there are a few out there used in good working order for u.der $200. .
Are you running d jet,? Go to jeff bowlsby's site he is a fuel injection guru, and has the bosch manuals and other resources, and he makes replacement wiring harnesses etc.
Auto atlanta, automotion and pelican parts all carry much of what you may need if you can't fins good used stuff here.
