Full Version: Its Suspension Time!
cha914
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear
-new poly bushings all around (from weltmeister...street compound)
-turbo tie rod kit
-new ball joints
...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable?
Thanks,
Tony
Bleyseng
Brad is having a class this saturday on front suspension work,if you can make it. Lookin the events calendar
Geoff
J P Stein
Are those gas shox?
If not, the fronts are a stinker to get back up thru the hole in the strut mount.
You will also find your tie rod ends reluctant to let go of the strut. I good tie rod puller is necessary and one of these smash.gif
Removing the tie rod from the steering rack is a challenge.
I used a monster pair of channel lock pliers. Access is a bitch.
Light a fire for the removal of the rubber bushings (a butane/propane torch).
Clean the bejesus out of the surfaces that the bushing ride on. .....I mean shiney clean.
Don't forget to bleed the brakes...set the venting clearances....yada.
Big freakin pipe wrench .....with cheater bar, for ball joint nut removal. Installation of the nut is *supposed* to be done with a torque wrench (165 ft/lbs) and the special tool that fits the nut.
There's more.....
As to the time frame. If you can work 20 hour days, eat no food , drink no beer, take no breaks, encounter no problems, take no time to pee (remember, no beer), have all the right tools close at hand, keep off the effin puter, AND make all the right moves....sure, peice of cake.
First time for the suspenders, eh?
cha914
Unfortunately the drive to CA and back from TX would take most of the rest of the week and weekend, but I would love to attend tongue.gif
JP - thanks for the tips...most sound familiar as I have read about many others doing the same, but this is the first time for me, and I know that its always different when you are the one under the car...
I don't need to finish this weekend, but it would be nice...
I am also planning brake work (new ss lines and adj prop valve), and I am not worried about them...done alot of brake stuff before...just never touched the suspension before.
can you take the steering rack out from the car to mess with it or is that a bad idea?
And what do you suggest as far as an alignment after such a weekend?
Thanks,
Tony
PS...Brad, I know you have said something before about cutting groves in the poly bushings to keep grease in them...got any pics?
Jeroen
How the fuck do you get the friggin struts off the balljoint?
(not the balljoint off the a-arm)
YES, it did remove the crossbolt and sprayed about a full can of "liquid wrench" on them already.
Is there a special tool, or do I just go at it with a bigger f-ing hamer?
Cheers,
Jeroen
bhfast
ball joint seperator it looks like a big fork, but with only 2 prongs.
brian
bhfast
local auto parts store should have it for around $7
brian
J P Stein
I didn't mean to sound rude.
I take a much more casual approach to working on the car.....
Jeroen
I got that one... won't work on the strut/balljoint
Couldn't get the tie-rods off with it either.
I used a different tool for the tie-rods.
I was scared the tool would break (not good if it's a loaner), but the tie-rod gave first
Darn, this stuff can get stuck!
Cheers,
Jeroen
bhfast
when i did mine it didjn't work either, so i used heat a beat the crap out of it with a hammer since i was replacing the balljoints anyway smash.gif ar15.gif
finally it ended up coming off
Brad Roberts
Here is how to get the ball joint out of the struts.
Use the torsion bars.
Pull the pin out of the bottom of the strut.
With the car on jackstands, place youre floorjack under the brake rotor hub.. not the actual rotor. Jack it up until you just start to see the car come off the jack stands. NOW. Hit the control arm with a 3lb sledge right next too the ball joint. The spring tension of the torsion bars and the 3lb sledge will have the control arm out of the strut very quickly. Remember that you can twist the struts out of your way.. you will have plenty of room to swing the hammer. I personally use a air chisel with a blunt end on it.
Please dont think anything will fly apart. You are just barely using the torsion bar tension to help with this (the full weight of the car is not on it)
This works. Dont let anybody tell you it doesnt. I leave the struts in the car and pull the control arms off the car. I then put the control arms back on the car and reassemble everything when I get the new bushings/bearings and torsion bars in them. THEN I do the shocks. I never completely remove the strut assemblies.
There is also NO need to remove the steering rack bolts. I only loosen the two large 19mm bolts that hold the rack in.. I dont even remove the splash shield unless I'm doing Turbo Tie rods.
B
cha914
I didn't take anything as rude...just want to enjoy this car for a change...and finally get it on the track after so long.
I really just wanted to get an estimate of how long it could take...so when its 4am on sat night I know I am close or I should just go to bed tongue.gif
and all you guys talking about needle bearings and monoball setups is making me want to spend ALOT more money than I should on this car...I just keep telling myself that I should put on the parts I have and upgrade later when I actually have some seat time in the car...crazy how these thousand dollar cars can get so expensive.
Tony
Bleyseng
Yeah, the ball joints get rusted in place to the strut so ya gotta use JP's method-BFH and heat. I also have a BFPB (Bigfuckingprybar) even 2 sizes (3 or 4 footer)that helps a lot too. Taking your time on this kind of project avoids making serious mistakes, like breaking or bending stuff. I like to clean up and repaint the parts as I go too. I know JP does look at all the pics he sends, the parts are like new before he re-installs em.
On the tie rod removeal, back the nut off so just a hair is past the threaded part. Then use the BFH lightly to break it loose from the strut. This is if you are saving the tie rod otherwise hit it good and hard.
Time for some in depth tech articles with pics it sounds like for this BBS.....
Geoff
Brad Roberts
Tony.
With proper tools.. I takes me 8 hours to completely do front and rear suspension on a 914. This is drive it in and roll it out for alignment.
Dont burn the rubber out if you have a press. It takes me 15minutes per side on the front control arms to push off the old ones. The rear takes about 30 minutes per side to push them out.
B
Brad Roberts
I dont use heat.. ever. Your lower ball joints dont always need replacing... so I dont use heat. It cooks the grease and melts the rubber protector.
B
cha914
ok...thats good info...I will plan on at least double your time since its my first try.
Brad...you also mentioned earlier how you cut groves into the poly bushings to hold the grease...you got any pics of this?
Thanks for the help,
Tony
Bleyseng
Well if you use too friggin much heat! Just a little on the strut so it expands and breaks the rust bond.
I like your method of using the torsion bars to help, have to try that one next time.
Brad Roberts
I tried to take pics of it... but none of them turned out. Just make a spiral path down the inside of them with something resembling a Dremel tool. I use a air grinder and carbide tip. Takes about 10 minutes per bushing. It really helps keep the grease in them. For what little material your removing..it will not compromise the structural integrety of the bushing. I cut the groove about half the thickness of a pencil (maybe a tad less). Just enough to hold the grease while you slide them on.
B
cha914
Ok...I have a little dremel...
how deep of a cut...from your description you just barely break the surface, correct?
Tony
Brad Roberts
Umm.. half the thickness of a No.2 Pencil (the yellow ones) This is a little more than breaking the surface.
The Dremel will take more time.. but not much. You can start on the bushings this week. Just sit dow with all of them in hand...
B
cha914
sorry, I got confused...when you said thickness, I thought you ment width of the disk...
Yea, I will start on those tonight probably...
Mueller
Back in the old days when I ran poly bushings instead of these really neat and surprisingly good deal needle bearings, LOL
I cut the groove with a Dremel as well, this is the bit to use, IMHO
IPB Image
Bleyseng
Nice pic! Thanks, you sell those too??
Brad Roberts
Mike would whore his ass out if he had too.
B
cha914
Thanks for all the help...let the games begin...
Tony
Gint
This is what it looks like when you get it all out and bead blasted.
A weekend huh? Could happen if your goals aren't to CW the whole thing and you don't have problems.
Took me 2 months. But that's just me. Jp's older'n me, but I probably work slower.
cha914
That looks real nice ginter...but mine are going to be rather brown and black...as long as they are functional it works for me...this is my car to learn on...
however, I am tired of learning how to fix it...I want to start learning how to drive it...after this weekend, or two, I will have taken everything off the car. So it will be time to have some fun with it.
Tony
Jeroen
wow! nice clean up!
did you have all that powdercoated, or is it DIY (por15 or something like it)?
good job!
Jeroen
Gint
I bead blasted it and powder coated it all right in my garage. Some pics here.
gklinger
QUOTE(Brad Roberts @ Jan 14 2003, 04:24 PM)
I remember seeing on the PP board a post from someone who had done this, as well as drilling and tapping for zerk fittings. Is this necessary? It sounds like a good idea from the future maintenance aspect, but I'm wondering if it's worth it. If you did this, could you just pump a good grease in there, or would the special poly grease be preferred?
Garry
Brad Roberts
Hi Garry,
I think the zert is going a little far. I personally goop them up real well before assembly. The problem is: if you dont have some kind of groove in them, all the goop slides out when you slide them onto the control arms. When you purchase them, they come with a very very sticky grease. I heard from another list that the sticky stuff is the stuff used by pool companies for swimming pool seals. I buy the grease in a large tub instead of using the tiny packets that they send. I end up getting double the grease in my bushings from the start.
Welcome to the board. Good question.
B
Gint
Brasshole, :sweet:
Where do you get the tub 'o grease? I need mass quantities for the Jeep bushings as well.
Dave_Darling
--DD
Gint
You know Dave, I read your reply and thought about it for all of 5 seconds....
Brad Roberts
Ginter,
I'll get the name of the stuff during the day (today) Bump this to the top so I can see it.
B
brant
bump...
Gint
Hi Brad!
Consider this a bump.
Gint
'nother bump
Brad Roberts
The tubs are so large (with no markings) I cant even locate the last place I bought it from. Hang in there..Tony and I have been working on this since lunch.
B
Jeroen
Hmmm... two guys looking for a heavy-duty lubricant
Cheers,
Jeroen
Brad Roberts
Crazy 'mericans.
Its real sticky stuff....
B
cha914
well...its sunday night, so I thought I would give you guys an update:
Rear of the car is finished...although, had a minor setback when my buddy ruined the center shaft on the control arm when torching out the bushings...luckly I have a parts car, and we had the replacement part ready to go in less than 2hrs...
I have the ttrods installed and I am in the process of installing the new front bushings...so I have about 3 hours of labor left before I can button it all back up...
So didn't quite finish in the weekend, but I had several slowdowns, and those 30 year old parts really don't want to come apart sometimes tongue.gif ... and I really need to make a good shop press, would have made things alot faster...
So, what I am going to need next is some good alignment specs...this car will see about 80-90 percent track (some autox but just for fun, want it to be dialed in for the big track), and the rest hard street...
Thanks again,
Tony
J P Stein
Gud job.
That would have taken take me a month....or 2.
