QUOTE(914Mels @ Sep 29 2011, 11:38 AM)
I pull my passenger side speaker cover to install my foot rest D ring and find just a 13mm or so hole in the frame where the screw is supposed to attach. Was there a nut spot welded inside the frame rail that fell off or what? I havent had that cover off for years and don't ever remember having a speaker screw in that spot.
If i recall correctly, they used those metal insert clips in the holes that allow you to use sheet-metal screws. The same type of insert is used in other places on the 914, like the door panels etc.
