QUOTE(7TPorsh @ Sep 29 2011, 11:42 AM)
Pardon my ignorance. i read Andy's 31 pages and used search as well as Haynes. i can't find a simple explanation on how to check/fill the tranny oil.
901 tranny. thx
There are 2 17mm drain plugs on the right side of the transmission case. One is low, we use this one to drain the gear oil. After draining the oil, you should wipe up any bits of shaving on the magnetic plug and re-install it. The other "upper" drain plug is used to fill the transmission. You would pump in gear oil until the oil is level with the upper drain hole.
You need a 17mm hex key to loosen the drain plugs,, I recomend using one of these,,,
