* I can do Pay Pal. If you'd like to pay with pay pal please add 4.4% they now charge.
I usually ship priority mail within 2 or 3 days of receiving funds. Thanks, WORTH LOOKING OVER!
209-537-3749
NOTE: these items are selling fast and I update as regularly as possible. If it's listed below I still have it for sale!
INTERIOR http://www.youtube.com/watch?v=rWa8oHbSeEM
1] set of "butt breathing" fabric seat inserts, both w/ good sensors {worn material} great to temporary swap in for hot sweaty days or long drives $65 shipped
1] 12 ft. of special twisted CHT wire (I'll measure soon) $25 shipped shipped
1] used turn signal switch (no harness)$15 shipped shipped
1] Custom vinyl covered 6 gauge console face panel, unfinished project. Set up for rocker switches and multiple lighting, comes with misc. add your gauge selection and finish $50 shipped
1] VDO oil temp. gauge $15 shipped
1] S/W 30 amp. Gauge $15 shipped
1] S/W oil temp. gauge $15 shipped
1] batch of misc. gauge brackets & lights $15 shipped
Or. . . ALL above gauges, brackets and face plate panel for 6 gauges and 2 rocker switches w/ lights! $85 shipped
1] 12 FT. of special spiral CHT wire $10 shipped
1] 72 up dash vent $25 shipped
1] sun visor center mount bracket $10 shipped
1] SET of chrome inner door handles/locks should clean up nice $50 SHIPPED
1] very nice "salvaged" decal for washer pressure {C.W. joytoy} $20 SHIPPED
EXTERIOR http://www.youtube.com/watch?v=uc2UeCO2t1U
1] fuel sending unit w/ extra ring & mounting hardware misc. $75 shipped
1] excellent front trunk latch w/ O.E. bolts & washers $55 SHIPPED
1] engine trunk lid complete w/ grill solid west coast part $75 + shipping
1] SET of excellent engine trunk lid hinges $35 SHIPPED
1] SET of special shouldered hood hinge pivot bolts w/ washers $25 SHIPPED
1] rear trunk lock cylinder w/ nut, No key $30 SHIPPED
1] bumper dog bone $10 shipped
1] door handle GREAT chrome, damage to lock release fork (finger broke)repairable? $20 shipped One of the two little "fingers" that move the plastic lock peice (that always seem to need to be placed) got broke during an attempt to change out the plastic piece. I'm hoping that someone has more patience than myself to salvage this otherwise excellent part.
1] excellent rear trunk drain funnel $12 shipped
1] left side front hood hinge, great cond. $25 SHIPPED
1] SET of headlight body metal covers, slight rust where paint chipped $30 SHIPPED
LIGHTING & ELECTRICAL http://www.youtube.com/watch?v=9kBQ0qkE4tE
1] side marker light base $15 shipped
1] fuel sending unit w/ring & misc. attaching hardware $75 shipped
1] cut alt harness (good 4 alt plug body or pigtail) $15 shipped
1] wiper switch excellent $50 shipped
1] emergency switch excellent $50 shipped
1] 72 turn signal switch $30 shipped
1] SET of headlight motor covers, no cracks, will clean up nice $30 SHIPPED
ENGINE http://www.youtube.com/watch?v=HvRTiY1MfPU
1] complete engine set of 1.7rockers for swivel conversion (no swivels or machining) $80 shipped
4] 1.7 high compression raised dome "euro" pistons and wrist pins $95 shipped
1] SET of 4 flat top 96mm pistons $110 SHIPPED
1] set of 4 very nice 1.7 rods $55 shipped
1] j-tube great shape $25 shipped
1] set of decent j-tube tin seals $20 shipped
1] good used starter $45 shipped
1] ribbed/insulated heat tube $20 shipped
1] NON sending unit oil cover and screen $20 shipped
1] oil cap $10 shipped
1] excellent rear trunk drain funnel $15 shipped
2] good used oil pumps $30 each shipped shipped or $50 both shipped
1] evaporative canister $30 shipped
1] NEW set of Napa Echlin points & condensor $30 SHIPPED
1] M.P.S. 75? 2.0 #0231172021 022906051E unmolested cap, W/ mounting bracket $65 SHIPPED SHIPPED (buy both 2.0 and this one for $120 SHIPPED)
3] 2.0 plenum sensors $30 SHIPPED
1] cold enrich injector (pass thru routing) $30 SHIPPED
1] cold enrich injector $30 SHIPPED
1] SET of 8 matched aluminum type IV pushrods, solvent cleaned glass checked straight $30 SHIPPED
1] very nice O.E.M, trans. Ground strap $30 SHIPPED
4] W7CCO BOSCH SUPER plugs, used but barely run for any time. $ free w/ any other item
DRIVETRAIN http://www.youtube.com/watch?v=Nzm_loMMj5s
1] O.E. steelie beauty ring $30 shipped
1] set of stub axles with couple $30 + shipping
2] main e-brake brake cables very nice condition $ 75 shipped
1] ftont strut odd shaped washers {3}
- it's NOT ok to contact this poster with services or other commercial interests
