Has anyone installed a 11-14mm steering rack spacer after the car was lowered, if so how did you do it.
Thanks for your replies, here's the problem. When the bolts are removed from the rack the rack cannot/won't move up high enough to get the spacers in. Does something else have to be loosen up to allow the rack to raise up high enough for the spacers to fit in.
