QUOTE(Brad Roberts @ Jul 21 2004, 08:18 PM)
Recently I'm subscribing to the large bar soft torsion theory. Buying new torsion bars is getting tougher for the 914 splines....so run a larger front bar to compensate. The ride quality is MUCH better.
B
Since we're talkin' theory, here's mine.
I wanna run the car as low as possible.
Ax venues are a bit rough....even the best of em'...mine are rougher than a cob (but that's my problem.) I could get another 3/4 inch of travel at the front with dropped $pindle$.
To run it low, stiffer springs and/or t-bars are necessary to keep the thing from bottoming out the shox. Stiffer t-bars will cause the car to push. Stiffer front AR bar will cause the car to push. Running on the front bumpstops will cause push.
Stiffer rear springs will cause oversteer....softer front AR bar will cause oversteer.
Front & rear tires of the same size will not necessarly be an advantage either way......less weight on the front (and some gratitius wheel spin) keeps the fronts cooler than the rears...and thus less sticky.
With the front bar at full soft, I'm now unweighting the inside rear tire occasionally.....makes that tire nice and warm. It still pushes a bit, but is gettin better. I'm gonna go to stiffer rear springs
to increase the roll stiffness without using a rear bar.
Prolly to 275 (from 225). Then (maybe) I can
I can add stiffness to the front bar without makin' it push.
It would be nice to have a simple theory/solution, eh?
JPIII.....seeking balance in all things, but specially in AX
