Hello,
I would like to know.. My car is missing most of the sail panel trim. Is it still available.. if so where.. is the place to get it
I purchased some trunk seals from pelican and they came rolled up and the part that should push onto the body is way too tight, If i try to install it, as is, the metal inside the trim will push through the rubber and scratch the paint.. I am dissapointed with pelican parts. Is there a good way to spread the seal so that it will install properly? with out damage to seal or paint?
I need to replace the targa front seals what do you with experience recommend?
What is the popular consensus for the best replacement distributor / points replacement set up, pertronix. mallory, crane.. carbs at the moment but I plan some sort of FI install in the winter..
Matt
