newdeal2
Jul 22 2004, 11:08 AM
I have a friend who is having a problem with the car running OK until it's fully warm and then it won't run under 4000 or so rpm's....???
Any ideas?
It's a d jet 1974 2 Liter
Andyrew
Jul 22 2004, 11:10 AM
UNDER 4k?
Wrong cam?
Dono..
Cloged injectors? incorrectly timed? Dwell? valves? spark? cloged fuel filter? engine toast?
Dont know...
Andrew
BahnBrenner914
Jul 26 2004, 02:41 PM
check all the vacuum tubes. i was working on my 2.0 and forgot a vaccum tube ( i think it hooked in under the throttle body ) and fired it up. when it idled at 4000 rpm i new something was wrong.
ChrisReale
Jul 26 2004, 02:53 PM
Check the timing, the TPS, do a valve adjust to make sure everything is in tip-top tune.
john rogers
Jul 26 2004, 03:02 PM
I'd say an air leak. Since it happens after it gets warm it is probably a joint such as the intake manifolds to head joint or a seam on the intake plenum or some other place that can open as it gets hot. Use the carb spray with a nozzle and spray around the whole intake system and it should show up. Good luck
