Full Version: Phenolic Block Intake Gaskets for 4 Bolt Heads
bobhasissues
Almost done reassembling my engine. My new AMC 2.0 heads have four bolts rather than three. My 2.0 gasket kit has the three bolt type intake gaskets. Where can I get the four bolt type without buying an entire gasket set?
I will drill the three hole gaskets if I absolutely have to, but would prefer to find a source for these gaskets.
Cap'n Krusty
I can look tomorrow if you can't find something closer .......
The Cap'n
McMark
Got a set here, $14 + shipping.
But, I bet if you call a euro shop tomorrow morning and ask for intake manifold gaskets for a 1971 914 1.7, or for a 1978 VW Bus 2.0, they'll be able to get them same day.
Part number is:
022 129 707 F
Dave_Darling
If your old heads had three-bolt intakes, they were probably better heads than your new ones. And your old engine tin won't fit correctly; the spark plug holes will be in the wrong place. You'll need to trade someone for 1.7 or 1.8 tin.
--DD
McMark
Not if it's AMC casting, reworked by Len Hoffmans to make Jake's LE heads. wink.gif
Dave_Darling
...That's why I said "probably"...
--DD
