Had a wonderful handling car from August 2010 till July 2011.Replaced entry level weltmeister 22mm sway bar with a speedway engineering used 22mm sway bar.I liked the idea of bearings through the body and the splined ends compared to the weltmeister setup.Modified the arms so they would work like sliders for adjustment.Have now run every 1/4 inch increment of adjustment from 3" to 7".Have not found the handling yet.In our current setup, that swaybar needs less than a 3" length on the arms.Would have a very small range of usable adjustment at those lengths.
Putting the weltmeister bar back on.
It's possible that something else has changed at the same time-or during the runs since then.
Results will tell.
JJackson
