Hello,
Thanks for looking, I am in the process of deciding the direction to go with my original engine.
My limitations are the stock 2.0 D-Jet, bumping up from the 1.7, my engine is an EA case with 330K miles, it mics OK so I am intending to use it with the necessary 2.0L parts.
So if I am correct a set of 2.0L heads that will pump 180CFM of air is a good start. Coupled with a 9550 Raby cam should be a good match.
Since I am working with the stock D-Jet, displacement should be limited to 2056cc.
So a stock stroke of 71mm and the increased bore to 96mm is what I am looking at.
I see there is some customization of connection rod size and piston pin size, I have questions about what these changes will accomplish?
Advice accepted.
More questions to follow,
Thanks again,
Mike
