Phoenix-MN
Oct 5 2011, 07:34 PM
I'm finishing up my interior and need to know what's the best way to fasten it to the floor? Glue, Tape, velcro?
Thanks
Paul
I believe they were originally glued in place. Be careful though that you get the right type of glue. Most glues will attack styrofoam. There are construction glues that are safe for foam but need one surface to be porous and might not set up when trying to stick to paint.
bigkensteele
Oct 5 2011, 08:08 PM
I would go with velcro before glue. It would afford you the ability to periodically inspect for rust, or remove it easily for whatever reason.
ConeDodger
Oct 5 2011, 10:04 PM
I removed mine from my '75 when I put in the Morph Subwoofer box. I don't recall it being anything but just wedged in place... I still have it sitting on a shelf if anyone needs one.
AZ914
Oct 6 2011, 07:43 AM
When redoing my carpets, I just 'placed' mine back, put the carpet over it. I don't think its going anywhere.
ptravnic
Oct 6 2011, 10:03 AM
QUOTE(AZ914 @ Oct 6 2011, 08:43 AM)
I did the same.
Phoenix-MN
Oct 6 2011, 10:58 AM
What I ended up doing was to buy a can of the expanding foam insulation and I sprayed four silver dollar size dots on it and pressed it in place. This will hold it and the bond can be easily broken to remove it.
Thanks for the replies
Paul
