McMark
Apr 16 2015, 12:16 PM
Certainly sounds like the harness.
Most likely culprit is the pins in the connector at the ECU. Those connectors are a major PITA to assemble. I'd suspect the serial connection wires themselves first.
VaccaRabite
Apr 16 2015, 02:06 PM
Will find out tonight. If I can get a connection with it my plan is to take it to Tonys tomorrow and put it back in the car. Go connector by connector until it fails to try and isolate the problem.
Zach
r_towle
Apr 16 2015, 02:24 PM
how many pins is the connector?
Have you considered buying a more rugged cable with the correct number of wires, and redo the connectors at each end to match the new wire?
Something that may be easier to assemble and more reliable??
I am watching with loads of curiosity because I am about to go down this road....
Rich
VaccaRabite
Apr 16 2015, 02:28 PM
Rich it's an amp-seal connector. Stop by my room at the Inn tonight it tomorrow night, I'll have it there. It's pretty rugged, and weatherproof.
Dr Evil
Apr 16 2015, 02:45 PM
Can't wait.
Dr Evil
Apr 16 2015, 02:47 PM
Pretty sure this is your problem. Need a new hampster.
crash914
Apr 16 2015, 02:57 PM
bring a gas mask...
VaccaRabite
Apr 17 2015, 07:00 PM
Well, not the harness.
I did find a fault in the fuse block, but that is fixed easy enough.
I connected the harness to my laptop via my little tester setup and had a connection instantly.
I am at a total loss as to what I need to do next.
Its got to be something in my car, which makes ZERO sense to me. I'm totally stumped.
Zach
VaccaRabite
Apr 20 2015, 12:11 PM
I now have full confidence in the harness.
When I did my test at Hershey I only used one ground point. It occured to me when I got sober the next day that there are 8 ground points. I married all the ground together when I got home on Sunday and retested.
ECU connected right away on the test bench.
So, its something in my car. YAY! ;-|
I dont wantto tow the car back home, but I dont see it making sense to work on it at Tony's as I have to take off work. I also dont want to pay tony to chase wires. I want to pay him to tune...
So I guess I have to tow the car home and start digging into it old school style. Which will have to be Friday, and then work on it while I still have my post Hershey 914 buzz going on.
I will admit I was pricing buying IDFs again to get the car moving under its own power. But I'm not giving up yet.
Zach
McMark
Apr 20 2015, 12:41 PM
Bad relay board? Test the power supply pin. It's the one in the white connector on the right/passenger side. Make sure it's getting 12v, maybe even try jumpering it straight to the battery.
VaccaRabite
Apr 20 2015, 01:00 PM
Relay board is first of the things I have to check.
The fuel pump also does not turn on when the key is turned, so I think there has to be some wierdness going on there.
When I had carbs it was not much of an issue.
Zach
crash914
Apr 20 2015, 01:01 PM
Hot wire. Eliminate everything and then add back one by one. Do you need to borrow my trailer?
r_towle
Apr 20 2015, 01:08 PM
VaccaRabite
Apr 20 2015, 03:32 PM
Herb, I'll just flat tow it. Thanks for the offer though!
McMark
Apr 20 2015, 04:05 PM
Main power relay on the board may not be tripping. That would cause both issues.
toon1
Apr 20 2015, 04:21 PM
relay board fuse, could be a switching transistor on the main board also.
VaccaRabite
Apr 20 2015, 06:34 PM
QUOTE(toon1 @ Apr 20 2015, 05:21 PM)
What do you mean?
Specifically the "switching transistor on the main board" part. Something in the cabin?
Zach
McMark
Apr 20 2015, 07:02 PM
Since he's got Megasquirt I listed in his signature I suspect he's talking about the MS board. Another reason I only use MicroSquirt.
VaccaRabite
Apr 22 2015, 07:38 PM
Since I will be doing some rewiring, I made something big.
All the 914 wire diagrams in one wall poster.
Big one is the engine side, since that will be my main target.
Little copy of the firewall forward.
Detail of the relay board - my likely nemesis.
And the ledgend for all three charts.
Calipers are in there for scale reference. It's 48x36 inches.
Click to view attachment That should help a bit.
Zach
VaccaRabite
Apr 24 2015, 09:02 AM
my 914 is back in my garage.
Work starts tonight...
Zach
crash914
Apr 24 2015, 09:57 AM
Are you using the ms relay board? I only use my original one for the voltage relay.
VaccaRabite
Apr 24 2015, 06:24 PM
QUOTE(crash914 @ Apr 24 2015, 10:57 AM)
Using the stock board for a few things. Some of the wires come out, some stay in.
Zach
toon1
Apr 25 2015, 09:40 AM
QUOTE(Vacca Rabite @ Apr 20 2015, 05:34 PM)
What do you mean?
Zach
The main MS board has switching transistors on it. There is in for the FP. The are small and could fail with a voltage overload.
Of you go to the megamanual It will show you where it is in the assembly instructions.
VaccaRabite
May 8 2015, 05:16 PM
As usual, life got in the way. But work started at home again on this today.
An old wire harness I got from Joe a longtime ago paid off. I needed to make a new 12 pin harness, and that got made today and is in the car. For the first time in YEARS my car will have reverse lights... assuming the switch at the transmission works.
I still need to test the main board, which will happen this evening after the kids go to bed. After that, I need to attach the plug to the crank fire wires I had to cut. Good times. This is what I want to get done tonight after the kids are in bed - assuming I can keep my eyes open.
Zach
crash914
May 8 2015, 05:35 PM
Fingers crossed
shag
May 8 2015, 06:15 PM
Good Luck, If it works are you going to the Import Show next weekend in Carlisle? It sure would be nice to meet you after being so close a couple of weeks ago. I just broke something in my shifter yesterday. I got carried away and shifted to hard or fast I guess. Paul in Harrisburg is going to get it fixed for me so I can attend the show next weekend.
John
VaccaRabite
May 8 2015, 06:54 PM
QUOTE(shag @ May 8 2015, 07:15 PM)
John
Nah, going to a different, non-porsche show next weekend.
Though I may drive up Sunday for the AX.... in my WRX.
Zach
r_towle
May 8 2015, 07:39 PM
Good luck, keep on it.
VaccaRabite
May 8 2015, 09:51 PM
Work complete.
Got a lot done today, in my own slow way. Both Molex plug ends are in and the crankfire wires are connected again. So tired I can barely see straight. Goodnight.
Zach
okieflyr
May 9 2015, 10:38 AM
I love your poster board! My schematic pages are all taped together and rolled up like the Dead Sea Scrolls. Good luck on this
r_towle
May 9 2015, 02:22 PM
Keep at it, even an hour a week and you will conquer your demon....
You should rename the car demon btw.
May 9 2015, 02:25 PM
QUOTE(r_towle @ May 9 2015, 04:22 PM)
progress is progress. It all ads up and soon you will be driving.
And then sell it and buy a Miata
balljoint
May 9 2015, 02:31 PM
QUOTE(okieflyr @ May 9 2015, 12:38 PM)
On the other side is a poster of Elle Macpherson.
VaccaRabite
May 9 2015, 03:22 PM
QUOTE(balljoint @ May 9 2015, 03:31 PM)
The other side is the hole I've been digging to freedom.
Zach
VaccaRabite
May 9 2015, 04:35 PM
With any luck, tonight I put the harness back in the car, unhooked aside from power and ground, and see if it connects.
Zach
VaccaRabite
May 9 2015, 07:26 PM
Booya!
We have a connection in the car. repeat! We have a connection in the car!
I had a really good feeling when I turned on the key and suddenly I heard the fuel pump turn on for a few seconds. I had not been getting that.
Loaded tuner studio, and the MS connected!
Slightly scary part is that I have NO CLUE what I did to make it start working. But it is WORKING!
Tomorrow, if I get released from mothers day duty, I'll start replacing the harness in the car. Right now its just the power and ground plugs installed.
The only thing that is not connected now which had been connected earlier is the crankfire sender. Easy enough to see if that kills it, but not tonight.
Zach
balljoint
May 9 2015, 07:37 PM
Send Mom to the spa, instruct kids to clean their rooms in 15 minute segments broken up by Pokemon episodes on Netflix. Attend to car.
saigon71
May 9 2015, 08:47 PM
QUOTE(Vacca Rabite @ May 9 2015, 09:26 PM)
Booya!
Zach
Great news!!!
aircooledtechguy
May 10 2015, 12:54 AM
QUOTE(Vacca Rabite @ May 9 2015, 06:26 PM)
Booya!
Zach
Great news Zach!! If you are using a VR sensor, remember that it will only work with the wires in the right order. So if you get nothing when you crank it, flip the wires around and try again.
crash914
May 10 2015, 07:07 AM
McMark
May 10 2015, 09:17 AM
QUOTE(aircooledtechguy @ May 9 2015, 11:54 PM)
In MicroSquirt, maybe others, you can switch this in software by switching the triggering from Going High to Going Low, or visa-versa.
VaccaRabite
May 10 2015, 09:36 PM
Well, found the issue!
Something is wrong with either the throttle position sensor or the wires for the throttle position sensor.
I thought I'd have an easy night hooking back up all the leads. Some of them are not easy to get to.
Turn the key, and no fuel pump. Dammit! I am now using the fuel pump as my dowsing rod. If it turns on foe a few seconds, I'm confident that the brain is working.
Take off a lead and try the pump. One by one. I got the point where I thought I had all the leads off and was starting to get really angry when I noticed the TPS tucked deep in there. Took that lead off and the fuel pump came back.
So, I'm going to replace the sensor, as I really doubt its the wires. I also happen to have another TPS on hand. But not tonight. Its 11:30 on a work night. I gotta get my ass in bed.
Frustrating, but at least I found the issue. I wish I had found it a month ago while the car was at Tony's shop.
Zach
toon1
May 10 2015, 11:50 PM
Are you saying the fuel pump turns on because of the TPS?
They should have noting to do with eachother
crash914
May 11 2015, 02:44 AM
shorted wires in the TPS, drawing down the operating voltage, fuel pump relay won't kick in for the short prime cycle.
fuel pump is a good test to see if the cpu is functioning correctly as it has full voltage...
914_teener
May 11 2015, 07:30 AM
QUOTE(crash914 @ May 11 2015, 01:44 AM)
Just like D.jet. No fuel pump no tickee.
VaccaRabite
May 11 2015, 06:00 PM
Replaced the TPS after work today. Tested it and and the fuel pump kicked over! We are in business.
Before I had to start being Dad, I was able to get the rest of the harness plugged back in, and turned the key for a quick test. The fuel pump kicked on just like it should.
I'm close to first start. Stuff left to do:
1) Calibrate sensors (TPS, AIT, CHT... I have a feeling I should have done this earlier, but I think I can do this with the sensors in the car.)
2) add fuel
3) put the air filter in
4) pressurize the fuel system and look for leaks
5) try to start it.
Would be totally awesome to be able to drive the car back to Tony's for final tuning.
Zach
r_towle
May 11 2015, 06:45 PM
Sweet
VaccaRabite
May 18 2015, 07:53 PM
Sensors are calibrated and seem to be working correctly.
Click to view attachmentI did run into a hiccup trying to update the ECU to the latest firmware. The installer would not install the firmware. More investigation is required, but I followed the printed firmware updater instructions to the letter.
Push comes to shove, I just run with the current installed firmware, which is 1 rev behind (for now).
Next step is fuel, and make sure my fuel system does not leak when pressurized.
You will note there is a "coolant temp" gauge. That is actually the head temp at the stock location (as opposed to under a spark plug). I have an under the spark plug CHT for the gauge in the car, giving reading for Cyl 3. Eventually I will install the 4 way. But first things first....
I also learned today that my throttle sticks open a little. There is something it grabs on before it gets fully closed. Thats why in the screen shot its reading at 10% open instead of fully closed.
I still have a few mysteries to work out with the spark tables. I set the offset to 295 degrees per Mark's instructions, but did not see where to set the initial cranking advance to 12 degrees. Still in the steep part of the learning curve for this software.
Zach
Dr Evil
May 18 2015, 09:07 PM
C'mon Hershey 2020! You can make it! Probably!
914itis
May 18 2015, 09:10 PM
