Built in 1999 it's an original 914-4 for SCCA runoffs, NO engine and tranny
BODY
Set for a 6cyl with a 6cyl bulkhead mount. Removable front and rear fenders and hood, deck and dash with dzus fastners. Chassis reinforced with proper 1.5" .095 wall steel roll cage. Larger front oil cooler with a Oberg filtering system with 16" oil lines. ATL fuel cell.
SUSP
McPherson struts on front with adjustable coilovers springs and rear. Shocks are double adjustable gas over Penske shocks all around. Rear trailing arms reinforced with mono balls.
BRAKES
Are large calipers front and rear. Dual hanging master cylinders with bias bar.
Run with 2.0 6cyl. and also ran with 2.8 in GT2. A 914-4 chassis. Atl fuel cell. Oberg oil system, Dual Brake master cylinders handing system, Penske coilover shocks double adjustable, RSR type front struts and rear in memo balls, w/17" alloys. mainly fiberglass fenders, carbon fiber dash. semi tube built on rack. Dry weight 1780lbs (less driver enigne tranny)
Car has been Scca, some vintage, PCA 1st Rennsport Lime rock 2001, Jefferson 500
Pictures here or if you have trouble with them please e-mail me.
http://s1091.photobucket.com/albums/i383/A...lbum_view_click
