Mueller
Jul 25 2004, 10:19 PM
I picked up an '96 VR6 to swap into my 914.
Specs of the motor:
6 cylinder, 2.8 liters
175HP w/175 ftlbs of torque (bone stock as of now)
6500 redline (easily 7k with minor work)
not too sure of the wieght of the motor, aluminum head, iron block
overall length of the engine is 21"
the widest part of the block/head assembly is about 9"
with the intake and exhaust, the width of the motor is 20"
from the crank centerline to the top of the motor: 18"
from the crank centerline to the bottom of the pan:8.5"
I half-measured my /4 and from the crank to bottom of the motor mount bar, it looked to be about 8" or so.
it looks like it'll be tight at the top/rear of the engine, it might possibly hit the trunk in the same spot the Chevy V8's distributor hits, luckly, I should have room to move the engine/transmission forward an inch or so if need be.....
front of motor:
Mueller
Jul 25 2004, 10:20 PM
"drivers" side (once installed)
Mueller
Jul 25 2004, 10:21 PM
rear of engine
dan10101
Jul 25 2004, 10:35 PM
Hmm, I'll watch this one closely. This is the swap I would do...
This or a 1.8 turbo...
So, does Momma know?
Andyrew
Jul 25 2004, 10:37 PM
Bow chicka wow now! (if you dont get it, dont worry)
Honestly I never thought an I 6 would fit. This is one of those with the pisonts kinda over lapping.. So its a v6? I remember you talking about it.
You have to be original eh?
So we talking chip and intake, (obvious exhaust..) Or you thinkin turbo? heh heh, Booooooost..
What about those turbo's you have? (they'll fit a SBC, RIGHT? Flip a switch in 4th gear... hehe, bye bye viper)
Dont ask for your radiator back, I know that you know its too big. lol. (I'll make it work for me. I like it
So whats your $$ estimate?
Andrew
Andyrew
Jul 25 2004, 10:40 PM
GET YOUR OWN DAD.
Then I'll race you. And we'll see who's got the betta swap.
Cus you KNOW that puny 951 wont run with me.
dan10101
Jul 25 2004, 10:43 PM
Maybe not, but Mikey will be cleaning up at the autocrosses...
Andyrew
Jul 25 2004, 10:47 PM
I have enough tire... Why cant I beat him? Like we said, aluminum stuff, and he's not more than 100 lbs lighter than me. I'll have sparse interior, fbg stuff....
I can do it. He can too.
Mueller
Jul 25 2004, 11:15 PM
I'm looking into the VW Corrado radiator...well, at least a good quality replacement unit....12 or 13 inches tall, and 28 inches wide....perfect fit into the front of the 914......not too sure if it would handle the heat of a higher horsepower V8 or not....the same radiator comes stock with 2 puller fans as well (master/slave fans, one motor, one belt)
ArtechnikA
Jul 26 2004, 04:38 AM
QUOTE(Andyrew @ Jul 25 2004, 08:37 PM)
...So its a v6?
technically, it's a straight 6 - IIRC each rod has its own crankthrow.
the 'V' shape is merely an artifact of offsetting every other bore circle.
Jeroen
Jul 26 2004, 05:01 AM
What gearbox are you gonna use?
Don't tell me you're putting the 914 up on stands again
cheers,
Jeroen
JWest
Jul 26 2004, 06:12 AM
Mike,
these radiators may be too tall at 19", but they are really cheap for a nice aluminum radiator.
Andyrew
Jul 26 2004, 06:43 AM
He just sold me his 19" tall radiator. Its pretty tall, and needs one heck of a slope to fit correctly in the front. Dont plan on putting anything else in there...
Andrew
andys
Jul 26 2004, 09:00 AM
QUOTE(James Adams @ Jul 26 2004, 04:12 AM)
Mike,
I think all the majors (C&R, Griffin, AFCO, Fluidyne, Ron Davis) make a 15 1/2" or 16" tall radiator that would not require it to be tilted too severely. I seem to recall it may be a Mustang application.
Andy
type47
Jul 26 2004, 11:33 AM
dan, my fantasy engine swap was a 924 turbo engine until i was told the engine is too long to install in a 914. isn't the 924 turbo just about the same as the vw 1.8T?
lapuwali
Jul 26 2004, 11:56 AM
Interesting that the water pump is on the back.
You snag the ECU, as well, or are you planning on using MS to power this thing?
phantom914
Jul 26 2004, 12:02 PM
How do the crank centerline to top and bottom dimensions compare to successsful engine swaps like a SBC? I'd like to know so I can compare my V6.
Andrew
Otmar
Jul 26 2004, 12:08 PM
That looks like a super engine to use, but is that the timing case on the back?
Rear (flywheel end) clearance sure is going to be "interesting"
I'm looking forward to seeing how it fits.
andys
Jul 26 2004, 03:21 PM
The odd placement of components is due to it being a transverse motor. This may or may not work to your benefit. Keep us posted on your progress.
Andy
Mueller
Jul 26 2004, 05:04 PM
the water pump is on "front" of the motor, they use a pipe/hose which goes to the "side" and "rear" of the motor.
I'll MS this one, I didn't want to deal with the factory ECU (drive-by-wire throttle body)
now I have to find a Ford 6 to grab the EDIS off of....the VR6 has no distributor, so I have to keep it crankfire ignition.
neo914-6
Aug 15 2004, 02:13 AM
Mike,
Do you have this link:
VW swapI got my engine recently, hope my/your old tranny holds up...
Felix
Mueller
Sep 30 2004, 04:02 PM
all right !!!!
the Kennedy Engineering adapter plate and flywheel showed up to HPH today....I also picked up a Stage II 228mm pressure plate from Brad...thanks
Andyrew
Sep 30 2004, 06:47 PM
Alright!!!
Just dont take as long as erm.. you normally do... lol
Mueller
Sep 30 2004, 10:46 PM
i hope to bolt up the transmission to the engine this weekend.........the hardest thing to decide is should I just go all out and start on the conversion or try to get the type IV in the car running perfect and then do the conversion ???? I'm kind of getting tired of working on something i know I'm going to yank out...
rick 918-S
Sep 30 2004, 11:06 PM
QUOTE(Mueller @ Sep 30 2004, 08:46 PM)
(Chant) 6! 6! 6! 6! 6! 6!
Andyrew
Sep 30 2004, 11:24 PM
QUOTE(Mueller @ Sep 30 2004, 09:46 PM)
I know EXACTLY how you feel....
I hated my T4... working on it was a pain... never could come up with answers...
I got to the point of doing a valve adjustment one day.. and the next day it was worse... then I broke my window... (and my g/f dumped me because I "scared her..".. Im tame if you know me, well cept when I get mad(rare)...).. It was at that point that I decided to stop and start a serious discussion with my parents about the v8 (by parents, I mean no brainstorming with dad.. but a "Mom.. can we do this?" thing...)
I'd say get the 6 running (I know I know... 2-5 months, but its not like you drive it much anyways....).. and map out everything for the 4 turbo and sell it as a project.... But not much we can say to sway your mighty mind of creativity...
mikerose
Oct 1 2004, 08:31 AM
Mike Have you told the wife yet
Mike
SteveSr
Oct 1 2004, 08:42 AM
Mike,that engine is VERY similar in size to my GM V6 swap. It too was a transverse engine and very tall looking but,my engine lid closes over it very nicely.
I had to cut the fire wall to clear the throttle body and water outlet.
I am using a RX-7 radiator laying down flat and exhausting out the bottom of the trunk. (see Phil Haun's Blue Thunder) Should be a really cool swap
SteveSr
fiid
Oct 1 2004, 09:17 AM
Slap the 4 in and drive it while you iron out any other issues with the engine.
You can also put in almost the entire cooling system before you need to pull the 4banger.
Let me know if/when you need a hand. I'm getting better at building motor mounts :-)
Fiid.
Mueller
Nov 14 2004, 08:09 PM
attempted to bolt on the adapter plate today, not sure if KEP made a mistake or the year of my engine is different than what I told them......I can cut the adapter plate to clear the engine part which is protruding, but i want to talk to KEP before to insure I didn't get the wrong part
Mueller
Nov 14 2004, 08:10 PM
anotherone
Mueller
lastone
rick 918-S
Nov 16 2004, 09:16 AM
cool stuff... how's it going?
Mueller
Nov 16 2004, 09:30 AM
just waiting to hear back from Kennedy on the adapter plate before I cut away the "offending" material
i bought a '73 /4 last night so that I have a teener to drive......the more I thought about it, i didn't want to put the megasquited /4 back in the current chassis since I'd have to pull it back out again to fit the VR6 motor into it.
Joe Bob
QUOTE(Mueller @ Nov 14 2004, 06:09 PM)
YEAH......
I'll be there at 7am.....
mikerose
Nov 16 2004, 09:34 AM
QUOTE(Mueller @ Nov 16 2004, 07:30 AM)
Cool
seanery
Nov 16 2004, 09:40 AM
let's see pics mikey!
Mueller
Nov 16 2004, 09:41 AM
QUOTE(mikerose @ Nov 16 2004, 08:34 AM)
Cool
the wife does not know about it yet
this car, but with steel rims instead
(don't think I want to put the enkies on it since I'd have to pull the fenders out...the enkies rub on my white car)
Mueller
Nov 16 2004, 09:42 AM
oh yea...tan interior which goes well with the green....
rick 918-S
Nov 16 2004, 09:43 AM
nice score!
mikerose
Nov 16 2004, 09:56 AM
It runs right
Andyrew
Nov 16 2004, 11:14 AM
Ya!!!
Love it!!!!
Chris914n6
Nov 18 2004, 11:28 PM
Looks like the water outlets will be a clearance problem with the trunk.
I don't know where I put my notes, but I think my Maxima V6 is a bit bigger on all dimensions.
You're engine lid should not be a problem, you can cut the crossbar if really needed. I didn't need to.
I'll have my engine out to do bay painting et al next month so if you need pics or ??? hit me up.
I get to make a new upper intake manifold this winter...
I'm trying really, really, hard not to put a turbo in at the same time
As useful as the fab'd upper rad inlet is with it's airbleeder, I sorta wish I used a 96ish Golf rad instead. A little taller at ~14 3/8" but sits flat on top so making a trunk divider would be easier & prettier.
Oh, and don't put the water filler on the pressure side... no matter how well it sits in the bay.
Took a long time to figure that bugger out.
"Where, O, where is my hot water going??"
Chris
neo914-6
Nov 19 2004, 12:18 AM
Hey that looks like Patricks car we saw at his shop last weekend.
Felix
Chris914n6
Nov 21 2004, 02:43 AM
Ok, found my notes...
front to mounting face - 20"
tranny overhang - 8" with 11" from top down
top to bottom - 27.5"
oil filter stuck out the front an extra 1.5" but I went with a remote filter.
With the new manifold, tranny overhang will be about 3" which will keep it out of the trunk.
Chris
Mueller
Nov 21 2004, 02:36 PM
motor is in the car for test fitting
it's going to be tight, right now the transmission is moved about 1" to 1.5"
forward....it looks like I'm going to have to modify the trunk wall a little to play it on the safe side...
Mueller
asdf
Mueller
Nov 21 2004, 02:37 PM
close fit firewall:
Mueller
Nov 21 2004, 02:38 PM
tight/interferance rear trunk:
Mueller
and last one
another view = tight/interferance rear trunk:
