QUOTE(nebreitling @ Jul 26 2004, 09:04 AM)
What would a valve which is tightening indicate?
it -can- mean the valve is receding, possibly due to erosion, or it can mean the valve is stretching (somewhat more likely, i think...) due to having been overheated or just fatigued from long life.
but tight valves are on their seats less time than loose valves, meaning they cool less well, and at some point, they just don't close, and they can burn easily. however, very small clearances also act like more cam (increased duration) which is yet another reason aircooled engines tend to run best right before they explode... producing more power == more heat but less time on seat means less cooling, which means more heat, which means the valve is more likely to stretch, which further tightens the clearances... that path can lead to destruction pretty quickly...
loose alves are kind of self-limiting. the engine makes noise and runs bad, and eventually almost anyone will notice and do something about it. when valves tighen up the engine runs better and quieter - right up until the time a valve breaks or the increased heat loosens a seat ...
