QUOTE(Bruce Hinds @ Oct 17 2011, 09:41 PM)
All that discussion on spring rate is interesting, but some of it depends too on how much tire he's going to be running.
300-400 lb springs would feel a lot softer with big meats under wide flares but probably feel like riding on bricks in a narrow body with 205/60s.
The other thing mentioned is all the extra weight. 250 lbs is not that much extra weight.
My SBC is just over 300 hp and i'm running 2oo lb springs, stock sway bar in the rear and a 911 bar up front, 22mm I think. The tires are 215/60s all the way around on 15x6 front and 15x7s rear.
I used to drive 34 miles of canyon road to Estes Park, Colo every week and it was just a HOOT. It was a perfect balance and I could steer it with throttle on the increasing and decreasing radius turns.
It all just has to balance to get a nice combination you like.
Hey Bruce,
Just for reference: my car runs 315/35-17 Hoosier DOT Slicks with a very stiff racing carcass. For a SOFTER ride, I'd go with your 215/60 tires with a tall, soft sidewall. Even on the Hoosiers, the ride would not upset the wife with 300 lb springs.
Secondly: the issue of weight is not just about lbs for a 914, it's about TALL weight that makes the car want to roll in corners. The 914 was designed with a low CG of a V8 engine and a low-roll chassis. After bump-steering all 4 corners, I learned that the rear suspension TOES-IN .100" for each inch of compression (the loaded tire in a corner) while the other wheel TOES-OUT the same .100" as the unloaded wheel. This means BOTH rear wheels turn toward the center of the corner in roll.
Thus, understeer is guaranteed unless mods are made. My guess is that Porsche
wanted to be SURE of no oversteer in the era of Ralph Nader.
I'm glad you like the balance of your car, but have a question about balance: With narrow tires, are you changing the handling with the trottle (power induced oversteer)? If you were to take a corner on the limit at 50-60 on a steady , slightly-positive throttle, what would the car do? Would it be neutral, understeering or oversteering?
-- I'm thinking understeer, but since U/S is stable, it's not a bad thing and especially if you like it. My case is very different: I'm trying to micro-tune the chassis balance for the max cornering speed on track and I HATE understeer.
Happy motoring on those Colorado roads!
Terry
