moparrob
Oct 17 2011, 08:59 PM
I guess it makes sense that after 35 years the gasket in the gas cap would rot out. I don't want this gasket dropping any more debris into my tank, so I cut out the old gasket.
Does anyone make a rubber replacement or does anyone know if a cork or rubber one is still available?
Thanks
moparrob
Oct 17 2011, 09:03 PM
I see this one for the plastic cap but for some reason I think the 75-76 are different...
new gasket for plastic capDoes anyone know for sure if it will work or not?
moparrob
Oct 17 2011, 09:06 PM
Also found this one....
another gasket
Steve
Oct 17 2011, 09:14 PM
70-73 is diferent. AA sells a cheap ugly replacement but it works.
http://www.autoatlanta.com/porsche-parts/p...?pn=343201551#a
moparrob
Oct 17 2011, 09:17 PM
Hmmm, I have a 74. Which one works for mine?
moparrob
Oct 17 2011, 09:19 PM
It looks like AA sells the entire cap but not just the gasket
Steve
Oct 17 2011, 09:28 PM
If its a screw on cap the gasket you listed will work. If its a bayonet type gas cap afaik you have to buy the whole cap.
moparrob
Oct 17 2011, 09:46 PM
I've got the bayonet type.
Really?
Why can't someone make a simple rubber seal which could be fit back under the 3 lugs of the bayonet mount? I looks like there is plenty of room to slide one in?
bigkensteele
Oct 17 2011, 10:49 PM
QUOTE(moparrob @ Oct 17 2011, 07:46 PM)
Really?
You should email Mark (aka Mikey914) at 914rubber.com. He is always looking for new stuff to produce. It may not happen soon enough for your need, but it would help the community!
moparrob
Oct 17 2011, 11:17 PM
Great idea. Will do.
Mikey914
Oct 18 2011, 09:37 PM
Simple part, just need a template to design tooling for. I figure 10 days. Most of that time will be wating for a sample the tooling will take me about 2 days tops.
$2.99 each on a group buy.
Who needs them? No cash yet, just sign up if you are interested.
McMark
Oct 18 2011, 09:43 PM
I'll take 5.
Oct 18 2011, 09:56 PM
QUOTE(McMark @ Oct 18 2011, 08:43 PM)
I'll take 5.
moparrob
Oct 18 2011, 10:05 PM
PM sent. I can send you an old gasket as a template if that helps.
pilothyer
Oct 18 2011, 10:36 PM
Several please...........Jerry
Mr.242
Oct 18 2011, 11:11 PM
+3
Wahoo...
bandjoey
Oct 18 2011, 11:12 PM
2
sean_v8_914
Oct 18 2011, 11:31 PM
Dude! you are the man.
i'm in for 5
sean_v8_914
Oct 18 2011, 11:32 PM
just make a whole 914, you're more than half way there
strawman
Oct 19 2011, 12:35 AM
I will take two!
DNHunt
Oct 19 2011, 07:14 AM
I'll take 2.
Dave
SLITS
Oct 19 2011, 07:17 AM
In for 5 ....
Are they a foot long?
tradisrad
Oct 19 2011, 07:25 AM
I'm in for 2 of 'em. Please PM when avaliable!
mikea100
Oct 19 2011, 07:26 AM
I'll take 2.
Brett W
Oct 19 2011, 07:42 AM
Back when I was daily driving my car, I was constantly having issues with the leaking cap seal. I bought a new cap, no change, tried two gaskets, no luck, tried a piece of rubber over the whole filler neck, no luck. The only solution I found was to run it below half tank if you are going to be doing and hard driving. It annoyed me to no end. I figured the only solution was to bolt on the later model 75-76 screw on caps.
Would be interesting to see if a solution could be found for the early setup, as the new car as has that style fillerneck.
Rotary'14
Oct 19 2011, 08:14 AM
QUOTE(Mikey914 @ Oct 18 2011, 08:37 PM)
I want 2 also!
-Robert
Steve
Oct 19 2011, 08:16 AM
I will take four!!
championgt1
Oct 19 2011, 08:42 AM
I will take two!!
mharmon
Oct 19 2011, 08:43 AM
I'm in for 2
rtalich
Oct 19 2011, 08:51 AM
Two for me please.
02loftsmoor
Oct 19 2011, 09:00 AM
put me on your list just starting on my 914
QUOTE(Mikey914 @ Oct 18 2011, 10:37 PM)
blitZ
Oct 19 2011, 09:31 AM
If these are for late models, I'll take two.
Thanks
eric9144
Oct 19 2011, 10:24 AM
Brand new fuel caps with seal, $30:
http://www.356devotion.com/914-4FuelCap.htmlLooks identical to the one on my '74
toolguy
Oct 19 2011, 10:37 AM
Mark. . I'll take 3 for the early gas cap. . . and can you make the same seal for the 914-6 oil cap. It's 36 mm x 50 mm. . ???
Dave
roadster fan
Oct 19 2011, 11:47 AM
I will take two.
Mark you are the MAN!
Jim
Mikey914
Oct 19 2011, 07:00 PM
QUOTE(toolguy @ Oct 19 2011, 09:37 AM)
Dave
Uhh....Yes
Vysoc
Oct 19 2011, 07:12 PM
Hello World,
If it will work with the late style gas tanks, I will take 5. My wife hates the smell of gasoline and I could never get the seals to work as they all cracked.
Wonder how she is going to like the smell of the new powerplant 2.5 flat six with Zeniths, that car is going to smell like gas every night of the week. Too bad for her.
I still want 5.
Thanks,
Vysoc
bigkensteele
Oct 19 2011, 07:22 PM
QUOTE(Vysoc @ Oct 19 2011, 05:12 PM)
Hello World,
I still want 5.
Thanks,
Vysoc
The subject gasket of this post will not fit a '75/6. Late cars have a plastic overflow tank and a screw on cap. The later design is superior in my opinion, but the weakness is the stupid paper gasket that the tank screws down on. They always crack. Rubber would help seal the smell, but my guess on why they use paper is that the fuel system is designed to operate with negative pressure and it might be too difficult to remove the cap if the seal were rubber, and a vacuum had formed inside the tank. That is just my theory. Otherwise, I can think of no reason why a rubber seal would not be a better solution.
wertygrog
Oct 19 2011, 09:46 PM
2 for me!!!
Gint
Oct 20 2011, 06:12 AM
I'm in for two.
Mikey914
Oct 20 2011, 09:28 AM
Just for clarification.
These will be in production shortly-
Early gas cap seal
Late gas cap seal
914-6 cap seal
BigDBass
Oct 20 2011, 09:55 AM
2 for me I guess!
Mikey914
Oct 21 2011, 07:25 PM
Done - PMs sent. I'll start a group buy thread to let all know.
Also did the late ones at the same time as the water-jet was already fired up.
moparrob
Oct 21 2011, 07:49 PM
You're awesome
jim_hoyland
Oct 21 2011, 07:56 PM
Are you doing the gasket for the plastic 1975 cap ?
Mikey914
Oct 21 2011, 08:03 PM
Yes
moparrob
Oct 21 2011, 08:24 PM
QUOTE(Mikey914 @ Oct 19 2011, 06:00 PM)
Dave
Uhh....Yes
Please start a new thread if and when you get around to making the 914-6 oil cap seals as I will need one also.
Thanks
