That looks great. Did you take any pictures of the process?
No I probably should have!
I measured the other side and did a rough outline of where it went.
Then I cut out the middle leaving enough metal to work with.
Then I cut slots in to the edge of where I thought the bend should be.
Then I started bending and comparing each piece until I thought it was close.
Then I welded each slot into the new position
I ground down the welds and welded again as necessary until it looked smooth
Then I used files for the finer detail and emery cloth to finish the cleaning
It just has a rough coat of primer now!
