QUOTE(matt5596 @ Mar 25 2013, 07:27 PM)
QUOTE(jcd914 @ Oct 19 2011, 08:08 PM)
You are asking about Front rotors, correct?
0.394 & 0.374 are both correct but different specs.
They can be machined to 0.394
they can be worn down to 0.374
Factory specs (mm): (I did the mm to in conversions)
Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in)
Min. Thickness after machining 10.0mm (0.394in)
Wear Limit 9.5mm (0.374in)
Jim
What about rear rotors?
These specs are not from a factory manual (don't know where my factory spec book is).
These are from a Peter R.D. Russek VW/Porsche 914/4 Repair Guide, I found on-line a couple years ago.
It is a nice little manual to have, little as in it fit in the glove box and can be with your 914 at all times.
All the info looks like it came from Porsche.
Thickness New: 9.5mm (0.374in)
Min. Thickness after machining 8.9mm (0.350in)
Variation in thickness 0.2mm(0.008in)
No wear limit is listed in this manual
Jim
