QUOTE(SLITS @ Oct 19 2011, 04:23 PM)
96 mm pistons & barrels = 2041 cc
That can't be right. The 71 stroke (stock 2.0 stroke) and 96mm cylinders make for 2056cc displacement.
In general, after you get to 96mm bore you start adding stroke. Over about 75-ish stroke, that gets rather complicated. After you get to 78mm stroke, you go back to larger bores but that also gets complicated and expensive.
Formula (for four-cylinder engines):
bore X bore X 3.1415926 X stroke / 1000 = displacement in cc.
So 96 * 96 * 3.1415926 * 76 / 1000 = 2200.422
--DD
