Full Version: water in my 3.2 oil
buck toenges
I am running a 3.2 with a k+n filter and maf. It has a velios oil tank. My oil is becoming milky. I assume there is some condensation issues going on but I also think the induction system of the air filter being exposed to the elements causing some of this. I have been told to run the beast for a while to burn off the water. What else should I do? Is there a way to protect the air filter from the wet? huh.gif
seanery
I think the person was right. IIRC, your oil is not getting up to temp. Run it good and hard. driving.gif
Jeroen
Yep, too many short distances will do that
Give the car a good run for it's money
If you think it's really bad, refresh the oil
cheers,
Jeroen
J P Stein
If the oil is visibly "milky", I'd drain it and start again.
I try not to fire mine up unless I'm gonna run it for 15-20 minutes minimum....more is better.
agree.gif drive it and get it warmed up. go for a 200-300 mile trip on some windy backroad and let her play.
then, change the oil to something good, like mobile1 ...
driving.gif Andy
tdgray
Sounds like you have a blown head gasket right on the water jacket biggrin.gif
