QUOTE(Tom @ Oct 22 2011, 06:10 PM)
While all of the ground wires in the 914 are as Jeff indicated, brown, there are ground wires that are white in the fuel injection harness! Try to see if you can determine what harness that wire comes from. Although it doesn't seem to be one of the injector grounds, it may be one of the wires to one of the sensors in the fuel injection harness. If you can determine which harness it comes from, maybe we can help you find where it goes to.
Tom
Tom,
I checked continuity of the broken wire and the wire I have hooked up to the aux air regulator on pin 12 of the connector. I have the correct wire to the aux air regulator.
The broken wire is coming out of the harness that has a white or slightly grey sheath. It exits next to the wires going over to the distributor.
The aux air white wire is coming out of the harness that has the black sheath.
Thanks for the help!
Steve
