QUOTE(kg6dxn @ Oct 24 2011, 05:22 PM)
Hit up a wrecking yard for early Audi's and Mercedes' and hack some out. It's a solder terminal. Heat it up and the wires fall out.
Gotta agree, most every 70's-80's Mercedes will have these wiring connectors. Maybe even some VW's
I've used several over the years for spare pins. When you pop the back of them you'll see that the wires verry simply soldered sideways through a hole in each of the pins.
It doesn't take much heat to break the solder joint and pull the wire free.
Note too: I've had odd electrical malfunctions that drove me nuts to try and find the shorts, only to find that 40 years on the road, with bumps and vibrations have caused the solder joint to break. It happens.
Ron
