according to the PP tech article..
http://www.pelicanparts.com/techarticles/9...alve_adjust.htm
TDC + rotor at (approx) 12 o'clock... adjust cylinder #1
TDC is determined via fan impeller marking and/or the marking on TOP of the tranny.
TDC + rotor at (approx) 9 o'clock... adjust cylinder #2
TDC + rotor at (approx) 6 o'clock... adjust cylinder #3
TDC + rotor at (approx) 3 o'clock... adjust cylinder #4
repeat and rinse, er, make double check
so, my question is: by the time the rotor turned one revolution (firing cylinder 1, 4, 3, and 2) the impelled fan goes spun 4 revolutions?
just want to confirm the above is true before i start ripping things apart.
on a side note.. please recommend a spark plug.. and how much gap on the plug should there be before i install it?
