QUOTE(vsg914 @ Oct 26 2011, 05:30 PM)
All your FI components need to be replaced? I seriously doubt that. There are a lot of here that have what you need. If your gonna split the case to replace the cam, your also gonna put in all new bearings, have the crank polished, bigger pistons and cylinders, etc. It always happens. Its the "while I'm in there syndrom (better known as Dirk Wrights desease). Leave the cam and you will be fine, or....Just fix the FI!
Well you see, we had a little bit of a fire issue. Kinda accidentally melted everything, including wire harness, and hoses and all that, plus the injectors themselves would need to be replaced and the pressure sensor took a crap. so, if the brain box still works, that would be only lead i have on the FI, minus the metal parts of the fuel line
