QUOTE(Dr Evil @ Oct 28 2011, 02:53 PM)
Clutch adjustment instructions are in the 31pages of tranz notes link in my signature, too. Check your clutch tube, too.
Am I missing something here ?
If the guy is a novice use terms he will understand.
Is there more than one inch of movement before resistance when you press the clutch pedal ? If so the clutch needs adjustment. Or possibly more.
Adjust the clutch cable at the transmission end.
As stated, on a un-molested car using two 11mm wrenches loosen the jamb nut from the adjuster and tighten the adjuster toward the pulley.
Correct adjustment is about 3/4" of "play" at the top of the pedals travel.
Too much play is like not pushing the pedal to the floor. This could be your only problem. If you are lucky.
Not enough play is like keeping your foot pressed on the pedal. It can cause constant clutch slipping and premature wear.
The other possibilities are a dis-located clutch cable guide tube or worn syncros.
The guide tube can come loose in the tunnel a couple of ways. Rust or poor assembly/fatigue. Both are bad but not terminal.
After these things are adjusted/checked and you still have difficulty you probably need the services of the esteemed Dr Evil.
Shifter bushings are the other possibility. That is another story.
And that's all I've got to say about that
