say you're cruising down a long hill at 60mph. you put the car into neutral bc there are no other cars around, motor idling nicely (1200 or 900rpm) and you see that this descent is about to level off and want to put your car in 5th gear..... what do you do (Keeanu Reeve)?
1. no gas, stomp on clutch, throw into 5th and gas/de-clutch as normal
2. quick blip gas to 2k (let go), quick stomp on clutch, quick throw into 5th then gas/de-clutch
3. stomp on clutch, shift into 5th, blip to 2k (let go) then gas/de-clutch
4. others (please describe)
c'mon.. help out an asian driver here <-- as close to beedy eye as the smilies can get (its ok, im chinese)
